0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Trying to remove the rear brake drums on my 46 1 1/2 ton. Any tips on how to get it off. I removed the axle part but stuck on the drum. The book talks about a puller? | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Back the brake adjusters off all the way and make sure the e brake cables are not tight. Remove the axle nut and outer wheel bearing. This should have the hub drum assembly loose fron the houseing, this comes off in one peace. If the adjusters are stuck use some pb blaster on them and take your time they will give it up don't force any thing or you will buying parts. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Take the drum and hub off together. Some separate and some don't, Scott | | |
