2 members (Otto Skorzeny, Jon G), 86 guests, and 3 robots.
Topics128,089
Posts1,056,344
Members48,442
#1465251 09/05/2022 5:23 PM
Hello,
I'm brand new on here, so take it easy on me ! HA ! I bought this truck 24 years ago, put it in my barn, it was driving great when I received it. But, life got in the way. Now, ready to restore it.
Need some general information on it ? Is it a 6500 ? The title says 1954, but not much else ? Can you all please give me some tips on how and where to get started. Located between Austin and San Antonio Tx. I appreciate your time and responses.
Welcome to the Stovebolt. Before we can help you we need more information. Serial numbers, engine numbers, block casting numbers, head casting numbers. Close-up photos of said numbers would be great. The number experts on here can tell you pretty much anything you need to know. Click on Tech Tips in the menu bar at the top of the page and scroll through for some excellent reading.
Stop by the Welcome Center and introduce yourself.
Yes Sir,
I sure will ! Headed to Welcome Center now... Thanks ! I'll go get the required photos in the next week or so, on the road now. And, I'll keep reading !
Authorized Pest
Authorized Pest
Cool looking truck. Will you be doing the resto yourself? Some? Parts?
Glad to see you were able to post images!! thumbs_up
As "just" said, got some good info in the Tech Tips. In there is an old Tech Tip, Beginning an old truck restoration. It may be a good starting point.
Also, you'll find the Shops Forums will be very helpful with some of your technical questions.
We are here to help. Just ask.
And welcome to the Bolt!
wave
~ Peggy M
1949 Chevrolet 3804
Thank You so much ! I'll be askin !!!!
Crusing in the Passing Lane
Do NOT crank the engine. Sitting that long, valves may be stuck, bending pushrods, etc. Remove any fuel in tank and carb. Remove valve cover, oil the valve stems liberally, tap on each valve with rubber hammer or 2 x 4, to verify they all move. Oil everything else, crank engine. Always use fresh fuel, look for local fuel supplier that sells non-alcohol fuel. Thank Obama!
Ed
Wouldn't hurt to put some ATF in all the cylinders and let it soak a while before you turn it over.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Do what you like ,it’s your truck ! For me make it mechanically sound and enjoy as is. It’s a great looking truck as it is right now. You can always make cosmetic changes down the road
Gerald
54 Chevy 3100
Anybody can do nothing
Rancher 3360 Almost missed your truck,looks like a good one,as Ed Pruss said be careful to soak your cylinders and be sure valves are free to work. Would send it thru by hand at first till you know it,s free to go. I swear by marvel mystery oil,keep a squirt can of it right on my lathe ways. That special smell of mmo when she fires up is like nascar smoke to a bolter !! Big bolts are big fu n On the old 2x4 trick watch out for intake valves that have a piston right at top dead center where the valve can hit the piston not likely but possible. Had one where all 6 intakes were bent from timing gear fail it would run just wouldn't start right. Peeled the head off ( was a beater) ground the 6 intakes till they cleaned up start fine then went ahead a long time !! Cheapo fix !!
Another vote for Marvel Mystery Oil.
Many applications on old engines , great stuff for soaking one that hasn’t been run for years.
looks a lot like my 54
Its what my '51 cab started it's life as. 15k gvwr 6400, but has 3600 badging on the replacement hood smile.
Chip
'Rusto-Mod'
'51 Chevy 3600 5 window | C4 Corvette front/rear suspension & drivetrain | everything else looks old and stock
'92 GMC Sonoma GT #15 of 806
'91 GMC Sonoma GT Extended cab 1 of 1
Trucks, Trucks.....and more Trucks
Curmudgeon
Curmudgeon
Frame
Waveski #1476305 11/23/2022 2:12 PM
Waveski I first saw MMO in the pumpers truck 70 years ago,we had it at home too. My 235's soak it in,drill press chuck likes to be soaked in Marvel too. Keep my metal pump oil can that hangs up on a nail head charged with marvel.
Marvel Mystery Oil is the miracle juice that has freed up many a marine gas engine - there is no worse environment for an engine than in the bilge of a sailboat, below the water line. Especially in salt water.
Stuck valves are a frequent problem; MMO has a great record both preventative and curative.
I can personally attest to the latter.
Welcome to the site. You should define restore because it means different things to different people. My 54 3100 is restored but updated in some ways to be a daily driver and a long-distance driver. BTW I have had it since 1983 and drove it for a long time as a third vehicle when my son got his license.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
My favorite AD is a 55 1st with a 47-53 front clip and an earlier shallow bed with slanted top rails. Of course the tractor engine has to give way to an LS and a Nova front frame clip. Just sit back and cruise at 75 all day.
[img]https://i.postimg.cc/ZC2D5QKw/truck-roll-pans-clips-003.jpg[/img]
[img]https://i.postimg.cc/9wTwtzZR/truck-roll-pans-clips-001.jpg[/img]
[img]https://i.postimg.cc/8stz9RPp/truck-roll-pans-clips-002.jpg[/img]
Evan
