Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#147009 05/27/2006 7:35 PM
I am finally getting ready to take my 1950 GMC 2 ton out for the first time. While I was running it, I noticed that the brake pedal is very hard to push and will only go down about an inch before it stops. This truck has all new wheel cylinders, master cylinder, and hydrovac and I bled the brakes as per the manual. Any idea what is causing this?
#147010 05/27/2006 9:08 PM
If it acts the same with the engine running and not running, I would suspect the hydrovac or a vacuum leak.
#147011 05/27/2006 9:19 PM
It's the same either way. The engine changes rmp slightly when the pedal is pushed.
#147012 05/27/2006 10:01 PM
Riding in the Passing Lane
Make shure you have vacuum at the booster. If the pedal goes down very little it,s doutful there is any more air in the system although there is a bleeder valve on the booster. If every thing is hooked up right & it still doesn,t work you must have gotten a bad booster. Make shure the port for air to go in the booster is open. It seems they had a hose that ran into the cab with a filter on the end.
1972 Chevy c10 Cheyenne Super
#147013 05/27/2006 11:27 PM
I just went down and checked vacuum and the vent. Vacuum is getting there and the vent was clear. While I was laying under it, I could hear the hydrovac making noise when the brake pedal was pressed. I really hope it isn't the hydrovac. I bought it a couple of years ago and the truck hasn't driven an inch yet.
#147014 05/29/2006 3:43 PM
The hydrovac is a fairly simple unit to tear apart. Mine was a remam.one that when I tore it apart I found it had been assy. using grease onthe leather piston seal. The grease had dried up. Cleaned it up,soaked the seal in oil, its works fine.
#147015 05/29/2006 5:28 PM
Mine is a rebuild too. That's definetly something to check.
