| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I am finally getting ready to take my 1950 GMC 2 ton out for the first time. While I was running it, I noticed that the brake pedal is very hard to push and will only go down about an inch before it stops. This truck has all new wheel cylinders, master cylinder, and hydrovac and I bled the brakes as per the manual. Any idea what is causing this? | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | If it acts the same with the engine running and not running, I would suspect the hydrovac or a vacuum leak. | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | It's the same either way. The engine changes rmp slightly when the pedal is pushed. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure you have vacuum at the booster. If the pedal goes down very little it,s doutful there is any more air in the system although there is a bleeder valve on the booster. If every thing is hooked up right & it still doesn,t work you must have gotten a bad booster. Make shure the port for air to go in the booster is open. It seems they had a hose that ran into the cab with a filter on the end. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | I just went down and checked vacuum and the vent. Vacuum is getting there and the vent was clear. While I was laying under it, I could hear the hydrovac making noise when the brake pedal was pressed. I really hope it isn't the hydrovac. I bought it a couple of years ago and the truck hasn't driven an inch yet. | | | | | Joined: Apr 2006 Posts: 9 New Guy | | New Guy Joined: Apr 2006 Posts: 9 | The hydrovac is a fairly simple unit to tear apart. Mine was a remam.one that when I tore it apart I found it had been assy. using grease onthe leather piston seal. The grease had dried up. Cleaned it up,soaked the seal in oil, its works fine. | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Mine is a rebuild too. That's definetly something to check. | | |
