5 members (Bisbee, LuckyLee, D B Cooper, Otto Skorzeny, Robert Crandall), 53 guests, and 2 robots.
Topics128,131
Posts1,056,723
Members48,454
#1467686 09/22/2022 12:38 PM
Just curious if anyone has split a 47-53 hood into the two separate halves and if so, what did you use to rejoin those halves? rivets? small nuts/bolts?
Thanks!
I have a 1954. I "split " the hood during my restoration process and rejoined it using flathead screws.
Ron - - Dusty53
1954 Chevy 3604
Insomniac
Insomniac
Welded the two halves together and ditched the centre dividing strip. I like the smooth hood, but am not entirely happy with the fit. The fit issue was mainly caused by a previous repair. Welding can overheat the hood and cause it to warp and "oil can". You have to go slow.
Gord πŸ‡¨πŸ‡¦
1954 1/2 ton 235 4 speed
Thanks Dusty and Gord!!
I have a SS dividing strip and want to keep it as "original" as practical!
Gord, I will keep an eye out for your truck! We have a condo in Victoria and our dream is to end up in Mill Bay, if prices smarten up that is!!!
Nuts and bolts.
My hood had a few of the rivets popped loose in the front where it had taken a hit on the driver's side. After persuading it back into the right shape, I replace those rivets with semi-tubular rivets. Machine screws and nuts would have worked just fine but being a bit AR, I went with the rivets to match the originals. I used machine screws and nuts temporarily.
20 plus years ago I split my hood so I could clean up the rust in the seam before bodywork and paint. Looks like I used 1/4” machine screws and nylocs to put it back together. Unless you’re AR or a purist I’d say just use screws to put it back together. Good luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Insomniac
Insomniac
Send me a PM (private message) if you will be in the area.
Gord πŸ‡¨πŸ‡¦
Just for the record, center strip was originally body colored on AD trucks, but you see more and more stainless these days. Maybe because they're only selling stainless nowadays, I dunno. By all means, make it the way YOU want it! thumbs_up
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
I bought a plain primered center strip a few years ago. I think they're still available.
I used stainless steel nuts bolts and lock washers that fit in the existing rivet holes.
I recall that #10 machine screws fit the existing holes.
Yes they do!
We used to do a lot of "smoothie" hoods but it has kind of died out. We welded the rear cross member to the underside of hood and fabricated a center cross member. Allowed a full week for welding and cooling. About a 1/4 to 3/8 bead maximum with cool to room temp between beads. Very little warp and good hood fit. Picture is of a 49 that was taken to show one piece windshield but hood shown also.
[img]https://i.postimg.cc/WdCXDw2x/one-piece-windshield-001.jpg[/img]
[img]https://i.postimg.cc/fJkcxSgs/one-piece-windshield-002.jpg[/img]
Evan
2 Offline
That image hosting website is hot trash
Please never use it again
- everybody
