2 members (TUTS 59, Maybellene), 157 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#146767 05/10/2006 4:40 AM
After reading the topic "wheel options" I am left with some questions. I have a 1956 4400. Are the 10 lug wheels a different bolt pattern than the late model gm wheels, like on say a GM motorhome chassis with 19.5" wheels? Has anyone attempted to install aftermarket wheels on their truck, like say alcoas? or do they not make a wheel that fits our size and our bolt pattern? Or am i stuck with just chroming the stock wheels?
Chris
1956 Chevrolet 4400
1959 Chevrolet Viking 60
1968 Chevrolet el Camino
2002 Chevrolet 1500HD 4x4
#146768 05/10/2006 2:52 PM
The bolt pattern is the same, the center hole is bigger on the later trucks. A hubcentric ring would be required to "correctly" run the later wheels.
Clearing the rear drums is the major problem with the 19.5" wheels. Some clear, some don't.
#146769 05/10/2006 6:34 PM
so the late model wheels will bolt right up, provided the drums clear? What is a "hubcentric" ring?
Chris
1956 Chevrolet 4400
#146770 05/10/2006 7:08 PM
Apprentice
Apprentice
Hub centric means that the loads from the weight of the truck are carried by a tight tolerance hole in the center of the wheel that fits over a raised ring on the hub. The lugs are only designed to hold the wheel on, not carry the weight of the truck. The newer wheels will bolt up, but the hole in the center of the rim is larger than the raised ring on the hubs. To properly and safely use the newer wheels, you need to machine metal rings that fit between the wheel center hole and the ring on the hub.
Joe Padavano
Joe Padavano
#146771 05/11/2006 2:38 PM
Thanks for the info guys.
Chris
1956 Chevrolet 4400
