3 members (JoergK., WICruiser, Cletus1950), 131 guests, and 2 robots.
Topics128,175
Posts1,057,053
Members48,460
Has anyone ever used lowering springs on the front of your 1941-46 Chevy 1/2 ton truck?
If so, where did you buy them?
How did you like them?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
I have springs from Detroit spring that set a little lower then stock on my'37. I was after a softer ride, not so much a lower ride, it just worked out that way. You will loose travel distance, so speed bumps or pot holes will bottom out the springs on the frame rails pretty easy. I added longer shackles in front to raise the body back up. If shipping wasn't so high, I would send them back to be raised up.
I am looking at them for my 58. I am doing a Napco build, but I don't want the front end lifted like they were stock. My plan is to get lowering springs for the front to bring the nose back down to a stock-ish height.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
