| | | Forums66 Topics128,134 Posts1,056,736 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2022 Posts: 100 'Bolter | | 'Bolter Joined: Aug 2022 Posts: 100 | Has anyone ever used lowering springs on the front of your 1941-46 Chevy 1/2 ton truck?
If so, where did you buy them? How did you like them?
Care taker of a 1946 1/2 ton. Pretty much period correct original. Danny T, from B’ham, Al
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | I have springs from Detroit spring that set a little lower then stock on my'37. I was after a softer ride, not so much a lower ride, it just worked out that way. You will loose travel distance, so speed bumps or pot holes will bottom out the springs on the frame rails pretty easy. I added longer shackles in front to raise the body back up. If shipping wasn't so high, I would send them back to be raised up. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I am looking at them for my 58. I am doing a Napco build, but I don't want the front end lifted like they were stock. My plan is to get lowering springs for the front to bring the nose back down to a stock-ish height. | | |
