2 members (Charles in CA, TrknGMC), 84 guests, and 2 robots.
Topics128,115
Posts1,056,633
Members48,450
Apprentice
Apprentice
I am trying to gain a little more highway speed and I can get some 10.00x20 inch tires and have calculated what my speed will be and it will be a lot better than what it is now so my question is will I lose to much power. My truck is a 51 2ton with a 261. Thanks for your help
you can always use that granny gear to get your moving
I shouldn't think there'd be a problem. Are you putting the big tires on the front also? If so, make sure you've got adequate clearance in the fenderwells, especially when turning. It should be OK, but it doesn't hurt to check.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
You might want to check the clearance you'd have between the rear tires; I can't fit bigger than 8.25x20's without them rubbing the sidewalls.
Authorized Pest
Authorized Pest
I don't know, but see if this will help any.
Peg
~ Peggy M
1949 Chevrolet 3804
