3 members (Gib70, cmayna, baldeagle), 117 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
I
I Offline
This is the first time that I've seen a upper radiator cowel installed.
Does anyone know why this was there or what it was for?
Never seen one either
First time I've seen one. Maybe they were for the larger trucks.
Never seen one on an older truck either. Have to say though that I like it. Anything to keep the heat monster at bay.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
Apprentice
Apprentice
Unless im mistaken,cowls are to force the air through the radiator, by the fan and keep the engine cooler at slower speeds and make cooling more efficent. Does this fan pull or push air?
good luck, wombat
I
I Offline
This pic came off of a 1940 1 1/2 ton that is out on eBay.
I have the same truck. I haven't paid close attention, but I believe that the fan pulls air.
Yep, it pulls air in thru the radiator to cool it. That cowling guides air from the top of the radiator into the fan.
I've had overheating problems in the past with missing fan shrouds on later model V-8s. Usually it's fine as long as the vehicle is moving. But when you start the stop n go stuff or just sitting there idling, then is when things start getting a bit overheated.
