0 members (), 221 guests, and 0 robots.
Topics128,162
Posts1,056,940
Members48,458
U
U Offline
Anyone have any ideas on where to get a new set of parking brake cables for a 48 1-1/2 ton with a 137" wheel base? Do they have universal kits or new ones, or do I have to go salvage?
On a lot of trucks including my '41 3/4 ton the front part of the system is just a straight rod with threaded ends. These attach to the forward end of the cables. If you are not interested in a totally original truck you could possibility use shorter cables and make up a longer rod. Of course you will have to see if the brake end of the cable would fit.
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
There are postings on this. One of them I remember stated that you can get new ones made up if you have the ends to the old ones.
1951 1 Ton Completed
U
U Offline
Thanks for the info. I'm very limited being on an island. I have tried all the auto parts stores here as well as some of the big trucking stores. I even tried to find some place that might be able to custom make it here,No luck.
I need the CABLE that attaches the rod from the e-brake handle to the lever on the rear axel backing plate. Will the 1 ton 64" cables work? I measured mine and it looks like 60"
http://community.webshots.com/photo/264653311/2011858710040363269HfySwD
http://community.webshots.com/photo/231809906/1264651491040363269ZhPciN
I
I Offline
Keep an eye on e-bay. I had a terrible time finding them for my 40, but eventually I found a NOS set on eBay.
I just bought some bulk cable and some clamps and hooked everything up. I wasn't into the resto look, I was after function,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I'm switching to rear of trans brake on my 49 4400 myself. Someone changed the rear, and cut off the cables. Most cables are rusted beyond use in junkyard or old parts trucks. You can get the ones for small trucks, but I here they are pretty cheapy, no good. Thinking maybe you can add on to them at one end with something to be long enough? Might have to move the frame caseing holders too to adapt. Just a thought?
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
I have those cables NOS and others .
Maybe some of the DIY cables might work for you?
http://www.lokar.com/index.htm
http://www.hotrodhotline.com/gennie/
There was a member on here some time ago that restored a green AD truck, about a 2 Ton with a dump back. He explained once how you could use a certain type of marine cable to repace the inner cable. It may still be posted somewhere. I don't know how one would attach the ends.
U
U Offline
You guys are awsome. Thanks for all the feed back. Chevyb, I will contact you.
Aloha!
