3 members (wilbur53, Rusty Rod, MickeyP), 62 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#146519 05/13/2006 10:48 AM
The tank on my '48 2t. is toast. Straps on the outside of the frame. Need to replace it (as well as the sending unit) but my catalogues offer tanks for the smaller trucks. Where would be a good place to start looking? Thanks.
#146520 05/13/2006 12:51 PM
used is all I know of that is available for those tanks.
1952 Chevrolet 3800 pickup
---All pictures---
#146521 05/13/2006 2:51 PM
Pete, when you say toast are talking smashed and dented, or rusted with holes in it? If rusty, how bad? I refurbished the tank on my '48 2t and it had a lot of pin holes on the frame side of the tank. I cleaned up the outside and used gas tank epoxy to cover all the holes and then I got Eastwood's gas tank cleaner/sealer kit and the thing is (so far) not leaking anywhere.
Keith
If it were easy they'd have grade schoolers doing it!
#146522 05/14/2006 11:31 AM
It's weeping around the bottom of the straps, so I'm assuming that it's pin-holed. I thought a used one of the same age would probably be questionable, if I could find one. Guess I'll go the rehab route, was hoping to find a repro to save time...thanks guys.
