1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | The tank on my '48 2t. is toast. Straps on the outside of the frame. Need to replace it (as well as the sending unit) but my catalogues offer tanks for the smaller trucks. Where would be a good place to start looking? Thanks. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | used is all I know of that is available for those tanks. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Pete, when you say toast are talking smashed and dented, or rusted with holes in it? If rusty, how bad? I refurbished the tank on my '48 2t and it had a lot of pin holes on the frame side of the tank. I cleaned up the outside and used gas tank epoxy to cover all the holes and then I got Eastwood's gas tank cleaner/sealer kit and the thing is (so far) not leaking anywhere.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | It's weeping around the bottom of the straps, so I'm assuming that it's pin-holed. I thought a used one of the same age would probably be questionable, if I could find one. Guess I'll go the rehab route, was hoping to find a repro to save time...thanks guys. | | |
