2 members (Peggy M, 1 invisible),
94
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Where can you buy brake rivets. I have a brand new set of shoes for my truck and no rivets. The local brake company wont sell rivets to the public I guess they want to do the whole job. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ttodd, what size are you looking for. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | 3/16 x 1/2 I think will do it probaly about 40 of them | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ttodd, I'll give you lots of info, you decide what you want to do. All the following are EUCLID part numbers. 3/16 x 3/8 head x 1/2 long semi tubular brass rivet P/N 7-8B 3/16 x 1/2 head x 1/2 long semi tubular brass rivet P/N 8-8B 3/16 x 3/8 head x 7/16 long semi tubular steel rivet [brass plated] P/N 7-7S 3/16 x 1/2 head x 1/2 long semi tubular steel rivet [brass plated] P/N 8-8S brass brake bolts 3/16 x 1 comes with washer, lock washer, and nut P/N E-633X brass brake bolts 3/16 x 1 comes with washer and keps nuts P/N E-917X steel brake bolts 3/16 x 1 comes with washer, lock washer, and nut P/N E-988X my vote is for the brass brake bolts P/N E-917X I'm used to working with those, but you decide, hope this helps. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Hey 3b I'm going to vote for 3/16 x 3/8 x 1/2 P/N 7-8b where do I find the EUCLID brake rivet store. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ttodd, Euclid is a brand of parts for heavy duty trucks, any good parts store that sells heavy duty truck parts should be able to get them. Their address is Euclid Industries, Inc. 6660 Beta Drive Cleveland, Ohio 44143-2321 Hope that helps. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Thanks 3B you are my brake rivet hero. If my local parts store don't have them I guess I'll try the manufacturer. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | since I'm ignorant about this, I'm gonna ask a question...
ya buy the brake (stopping) material and put the rivets on yerself on the big bolts... or what?
-W | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Woogeroo, You can buy friction material with different co-efficients of friction depending on your application, then you can attach those linnings to your shoes using rivets or special bolts. Or you can buy your shoes and linnings pre assembled, or your local brake shop can attach linnings to your shoes for you, many ways to go, hope that helps. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | This is a great way to fix brakes that you can not find parts for. I just put a two speed rear end out of a early model fQrd in my doodle bug. People think huck brakes are hard to find parts for try finding ancor brake parts for the old fQrds can't be done so you just make them yourself. By the way 3B got the rivets shoes installed life is good. Made the shoes out of some parts from a 6x6 military truck. | | |
