5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#146354 04/03/2006 2:58 PM
Where can you buy brake rivets. I have a brand new set of shoes for my truck and no rivets. The local brake company wont sell rivets to the public I guess they want to do the whole job.
#146355 04/03/2006 3:59 PM
3B Offline
Hy ttodd, what size are you looking for.
#146356 04/03/2006 6:21 PM
3/16 x 1/2 I think will do it probaly about 40 of them
#146357 04/04/2006 12:49 AM
3B Offline
Hy ttodd, I'll give you lots of info, you decide what you want to do.
All the following are EUCLID part numbers.
3/16 x 3/8 head x 1/2 long semi tubular brass rivet P/N 7-8B
3/16 x 1/2 head x 1/2 long semi tubular brass rivet P/N 8-8B
3/16 x 3/8 head x 7/16 long semi tubular steel rivet [brass plated] P/N 7-7S
3/16 x 1/2 head x 1/2 long semi tubular steel rivet [brass plated] P/N 8-8S
brass brake bolts 3/16 x 1 comes with washer, lock washer, and nut P/N E-633X
brass brake bolts 3/16 x 1 comes with washer and keps nuts P/N E-917X
steel brake bolts 3/16 x 1 comes with washer, lock washer, and nut P/N E-988X
my vote is for the brass brake bolts P/N E-917X I'm used to working with those, but you decide, hope this helps.
#146358 04/04/2006 3:42 AM
Hey 3b I'm going to vote for 3/16 x 3/8 x 1/2 P/N 7-8b where do I find the EUCLID brake rivet store.
#146359 04/04/2006 4:07 AM
3B Offline
Hy ttodd, Euclid is a brand of parts for heavy duty trucks, any good parts store that sells heavy duty truck parts should be able to get them. Their address is Euclid Industries, Inc.
6660 Beta Drive Cleveland, Ohio 44143-2321 Hope that helps.
#146360 04/04/2006 9:55 AM
Thanks 3B you are my brake rivet hero. If my local parts store don't have them I guess I'll try the manufacturer.
#146361 04/05/2006 11:37 AM
Socket Breaker
Socket Breaker
W Online: Happy
since I'm ignorant about this, I'm gonna ask a question...
ya buy the brake (stopping) material and put the rivets on yerself on the big bolts... or what?
-W
#146362 04/06/2006 12:27 AM
3B Offline
Hy Woogeroo, You can buy friction material with different co-efficients of friction depending on your application, then you can attach those linnings to your shoes using rivets or special bolts. Or you can buy your shoes and linnings pre assembled, or your local brake shop can attach linnings to your shoes for you, many ways to go, hope that helps.
#146363 04/07/2006 1:26 AM
This is a great way to fix brakes that you can not find parts for. I just put a two speed rear end out of a early model fQrd in my doodle bug. People think huck brakes are hard to find parts for try finding ancor brake parts for the old fQrds can't be done so you just make them yourself. By the way 3B got the rivets shoes installed life is good. Made the shoes out of some parts from a 6x6 military truck.
