4 members (rfs56trk, 2-Ton, ‘37ChevyPU, TUTS 59), 63 guests, and 2 robots.
Topics128,203
Posts1,057,412
Members48,471
Hi all,
I think my tires are 32” .. have to get to shop and measure.. i aint gonna do fenders so going to need some strong metal and mud flaps for this dually setup. Any suggestions on what to buy and where?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Hey 38_1.5Ton,
You may need to go to a vendor like this below (just one of many I found doing quick web search):
https://www.raneystruckparts.com/mud-flap-rear-frame-accessories/
Mounting of the hanger brackets may take some added fabrication, then your choice of "flaps" to give you desired results.
Appears there may be just enough frame rail tail sections' extending beyond spring mounts to place hangers and still clear tires.
Let us know how things work out.
Dan wave
~ Dan
1951 Chevy 3 window 3100
Will you be adding a body to your truck, if so then the flaps can hang from that. If not then you can make a hanger for them that attaches to the rear frame rail. If temporary you can bolt a 2" x 2" piece of angle iron across the back of the frame and hang them from that.
Flaps come in 24, 30 and 36" heights. Position them so they don't drag when loaded.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
There are some out there from truck stops with their logo on them.Amazon.. Then make your own brackets that were suggested'
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Sure, this will have a flat bed.. if I can find planed oak that is not $$$$$$$$$$$$$$$$$ somewhere in PA/MD area..... Thanks for the suggestions guys. I wasnt even sure what to search for on this.. After following your links.. one of the hangers has a spring loaded type. Is there some advantage to this?
This is no longer the case, but we used to have a Delta Truck Body plant in the next town over. When they put their body on a truck, they put their own mud flaps on, with their logo, and took off whatever the truck had on it when it came in. I had a friend who worked there part time. He was able to get me a brand new set of flaps with the name of some truck stop in Nebraska, I believe. I have them on my '47. They look great, and didn't cost me anything!
I guess my point is, if you have a place like that near you, check with them.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
By law flaps have to be no higher than 8" from the ground. I don't recommend getting much lower than that either. Otherwise you will be backing over them in soft ground or backing up to a curb. I have owned trucks for 58 years and sill own a dozen trucks. And have paid for a lot of flaps over the years. I don't recall ever being written up for flaps more than 8", but every trooper has his own ideas of which laws should be enforced. I would recommend Buyers Products. They have a good product at a reasonable price.
The bolt on square stock holders sell for around $50 a pair. It is hardly worth trying to build something for that price. And not all flaps have the holes in the same place. On the square stock holders you can adjust the brackets to the holes. The TBOZZ E-Coating Black Mud Flap Hanger Bracket with Hardware Sold by Pair sold on Amazon will work just fine. I use Betts 3/4", They cost twice as much, but my trucks are on the road every day.
back yard wrench turner
I found a set from the selling dealer. The dealer went out of business in the 80's.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
They look a whole lot better than generic ones.
What- - - - -no chrome nekkid lady decoration on the flaps?
LOL!
Moderator
Moderator
2 Online: Content
Eric, That just ain't right!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
OH GOD! I can't unsee that. eek
A piece of 1x1 angle iron that runs all the way across from one side to the other and then a piece of 1/8" flat steel the width of the flap to sandwich the flap to the angle iron.
24601
24601
Another great place to find mud flaps is ... the side of the road! I have picked up a few flaps laying on the side of the road. At my work, we tend to lose a flap now and then, and flaps aren't exactly cheap anymore. In fact, I have one from the road in the cab of my work truck now -- to remind me to put it on...
If different logo/designs/wording is a problem, just turn 'em around so the plain black side faces rearward, wink
The side of the road is also a good source for bungee cords ... Its amazing how many you see once you start looking ...
Eric, Normally for a post like that we'd send you a PM. But for THAT one, I'm afraid we're going to have to administer a severe beating.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
grin Jerry mentioned the mudflap girls, and I remembered having that picture, so I couldn't resist... I saw that on the hood of an AD at the Lone Star Roundup a few years ago.
Can I help? grin
38 1.5 ton Doesn't your local parts store have flaps with their name on em ?? Mine are Fisher auto those guys are like family !! I certainly spend enough there !!! you'll learn that if you back up to gravel pile it'll pull your flaps off. Also for dress up you can put a stainless plate at the bottom so the flap doesn't sail so bad,or use those nekkid ladies as hot rod said this may not meet with approval from other sources though LOL .
Big Bolt Forum Moderator
I got mine at Napa.
Mike
