8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 6 New Guy | | New Guy Joined: Feb 2006 Posts: 6 | On my 55 I'm replacing the rear axle seals and am having a hard time pulling the axles out. When I removed the hub cover plates there is a threaded hole in the axle like its giving you a place to pull on- but the shaft only moves in and out about 1/8" and wont pull out. Is there a retainer in the carrier holding them? It's a two ton with a 2 speed rear. Any ideas or maybe refer me to some literature? Thanks- | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hey Wrecker55,No there is no retainer in the carrier to hold the axles in.Make sure the load is off the driveline(jacked up)and give the axle a smack on the end with a brass hammer.It should pop out.Let me know how you make out.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Yea Spanky,I think you have seen my '53 6500,thanks to Metalman.We have talked in the past.I also have a 51 3600 with a Holmes 470 that I think I will part out soon.Too darn cold to do much now.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Put a 1/2" fine thread bolt in that hole to give you something to grab the axle by. Give it a few quick pulls and it will come right out. Sometimes there's a slight bur on the end of the drum or the gasket it still stuck onto the drum, but it will slide right out, no retainer, Scott | | | | | Joined: Feb 2006 Posts: 6 New Guy | | New Guy Joined: Feb 2006 Posts: 6 | Thanks for the advice! Screwed in the bolt and gave it a tap with the slide hammer and it popped right out. My joy was short lived though, pulled the hub and it looks like the bearings are shot. Man, are they expensive to replace! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Should only have to do it once though. Good luck with it, Scott | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | If a Napa type auto parts store can't get them try Old Car Bearings Inc.@ 1-810-969-2628 or try to do a Google to see if they have a web site.
