1 members (1 invisible), 89 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#146136 03/18/2006 4:08 PM
On my 55 I'm replacing the rear axle seals and am having a hard time pulling the axles out. When I removed the hub cover plates there is a threaded hole in the axle like its giving you a place to pull on- but the shaft only moves in and out about 1/8" and wont pull out. Is there a retainer in the carrier holding them? It's a two ton with a 2 speed rear. Any ideas or maybe refer me to some literature? Thanks-
#146137 03/18/2006 4:19 PM
Hey Wrecker55,No there is no retainer in the carrier to hold the axles in.Make sure the load is off the driveline(jacked up)and give the axle a smack on the end with a brass hammer.It should pop out.Let me know how you make out.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#146138 03/18/2006 4:25 PM
Hey gtow69, Got any pictures of your wrecker. I happen to collect Antique Holmes Wreckers. See them here, http://community.webshots.com/album/116208177WBeZZP
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#146139 03/18/2006 4:52 PM
Yea Spanky,I think you have seen my '53 6500,thanks to Metalman.We have talked in the past.I also have a 51 3600 with a Holmes 470 that I think I will part out soon.Too darn cold to do much now.
Wanted Good Woman:
#146140 03/18/2006 9:11 PM
Put a 1/2" fine thread bolt in that hole to give you something to grab the axle by. Give it a few quick pulls and it will come right out. Sometimes there's a slight bur on the end of the drum or the gasket it still stuck onto the drum, but it will slide right out, no retainer,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#146141 03/20/2006 11:55 PM
Thanks for the advice! Screwed in the bolt and gave it a tap with the slide hammer and it popped right out. My joy was short lived though, pulled the hub and it looks like the bearings are shot. Man, are they expensive to replace!
#146142 03/21/2006 4:22 AM
Should only have to do it once though. Good luck with it,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#146143 04/02/2006 10:11 PM
If a Napa type auto parts store can't get them try Old Car Bearings Inc.@ 1-810-969-2628 or try to do a Google to see if they have a web site.
Wanted Good Woman:
