5 members (KEVINSKI, FAST55, Hanks custodian, Otto Skorzeny, Rusted Nut), 66 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
#146072 03/12/2006 6:16 AM
Apprentice
Apprentice
I was only suppose to swap motors,but you all know how it is.I took doghouse off to swap motors easier.Then I thought I would just go ahead and clean frame before puttin in other motor.Then one thing led to another and before I knew it the wife came out to the barn and saw I took cab off.
Sooooooooo,since then I have alot of time to myslf now LOL just kiddin.Since I am now into a frame off restro,I need some rust proofing tips.
Like what products have you all used and had luck with.
#146073 03/12/2006 5:14 PM
You can't beat Por15, just don't get any on you because it won't come off. It has to wear off. Eastwood also has a product that is similar.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#146074 03/12/2006 5:29 PM
Riding in the Passing Lane
I like Rustoleum rusty-metal primer.
1972 Chevy c10 Cheyenne Super
#146075 03/13/2006 2:31 AM
Apprentice
Apprentice
Thanks for the input.Cant wait to get the frame done so I can start on cab.
#146076 03/14/2006 4:11 AM
Y
Junior Member
Junior Member
Y Offline
JASCO prep & prime $13 per gallon, just wire brush it to get the scale off. Works kind of like naval jelly, turns rust into a dark, hard and paintable surface. You can even use it to paint galvenized.
1951 6400
1954 6100 dump
2 1962 IHC scouts
#146077 03/15/2006 11:49 AM
You might want to pick up a cheap needlescaler from HF...O.K. for occasional use. Works slick for the scaled rust on frames. You might be suprised how little metal is left, but now's a good time to add fishplates. The frame on a '67 broke clean in half when I dropped the dump body on it...bummer.
#146078 03/15/2006 2:17 PM
Apprentice
Apprentice
Thanks Pete,Since I do plan on using it I will be going over the frame real good.I figure that with my luck it will break when im 20 moiles from home.LOL
#146079 03/15/2006 3:01 PM
4t9er
I used "Right Stuff" seems to work OK. Bought at FLAPS for $5 a quart Pics below 13 shows it wet 001 is dry. My 4t6 frame is on there also. Good Luck
Dan
http://community.webshots.com/mypho...=1513725618071274430&security=DlqfHb
#146080 03/16/2006 9:10 AM
Apprentice
Apprentice
Thanks 4t6, Liked the pics and info
#146081 03/21/2006 9:12 PM
U
U Offline
I'm with Yabica, Jasco prep and primer. I put the gallon in a yard weed sprayer and sprayed the whole truck, even in the doors. It converts any rust visible or hidden back to metal. This helps even with preserving projects. I had a piece of bare metal with the jasco on and it did not rust for 6+ months in the salty hawaii air.
