2 members (Gdads51, 1955 1 Series), 137 guests, and 3 robots.
Topics128,089
Posts1,056,352
Members48,442
#1459720 07/22/2022 2:53 AM
I am in the process of cab removal on my 1948 4000 series cab over. I have found the bolts on each side above the front tires, but I do not see any others. I see some brackets at the rear of the cab but no bolts just empty holes going up thru the brackets. I am removing the cab in one piece, fenders, hood and all. I removed the radiator and found 2 bolt holes in bottom of radiator support and again no bolts... did they all just fall out over time or were they never there. This truck has had a rough life and has been parked for a very long time. Does anyone have any pictures of where they all are.
Crusing in the Passing Lane
It is very to remove the front fenders, core support, etc. as one piece with two guys, then the cab is pretty much ‘stand alone’, much easier to remove.
Ed
GMwrencher Those rear cab mounts intruduce rubber into the mount system because you know when the frame flexes something has to give. Those old time rivited frame guys really put the frame thru it's paces,and afterwords frame still strajght rivets tight ready for more !! My 51 6400 out there has hauled thousands of bushels still just fine,had a few chain bites from poor hitching,nothing a BFH wouldn't take care of !!
Welcome to the Stovebolt! wave
Pulling the entire cab with the front clip attached will put a lot of stress on the fenders. If it were me I'd remove the front clip and then lift the cab off.
The clip is attached at the firewall via bolts at the top and bottom of the fenders, at the inner fender/firewall and under the core support...as long as you can get at the bolts it's pretty easy.
Also, if your truck is a COE than it's a 5000 Series...the 4000 and 6000 Series are conventional cabs.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B the cab and front clip on my COE are very rough and rusted out. The rot is why I was wanting to pull it all in one piece. I am not worried about the weight as I have equipment that I can use to pick up everything. I was really wanting to find out the locations of all the bolts I need to remove to be able to get the cab off the substruction. I see the single big bolts above the front tire on each side. I can see what appears to be mounts at rear of cab but there is no rubber there and no bolts, just holes where the bolts would be??
The COE (5000 series) use the same style of shackles at the rear as the conventional cabs, and the bolts you found near the kick panels. The shackles are shown in the Factory Assembly Manual (Section 1, Sheet 3.16) They differ from the conventional cabs in that the frame side brackets are mounted to the subframe horizontally as opposed to vertically on the frame for conventional cabs.
It sounds like someone has already unbolted the shackles at the rear.
