7 members (Bill Hanlon, 52Carl, Hotrod Lincoln, NJC, Stovebolt48, Gdads51, 1 invisible),
54
Mod | | | Forums66 Topics128,180 Posts1,057,163 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | I have a 1/2 ton truck. Can I put a big bolt cab,"I can get a rust free one" on and use 1/2 ton fenders or is the cowel area larger? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The cabs are the same from the little 1/2 tons to the larger 2 tons and everything in between, provided we're talking about an AD series truck, Scott | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Not sure what the AD series is. I've got a 48 first series. | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Not sure what the AD series is. I've got a 48 first series. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 75, I could go on about what AD refers to but if you do a search for AD truck you will find reams of material. Good luck with your truck and don't forget the pictures! | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | So could a 1948 Thrift master be considered an AD? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | An AD series (Advanced Design) truck goes from 47 second series to 55 first series. So, yes, you have an AD series truck. The trucks before the AD's were nicknamed the Art Deco's and the trucks after were called the Task Force trucks. Hope that helps some, welcome to the Stovebolt, Scott | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Yes sir! Thanks for the info,"I've got lots of parts missing!" | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | As I'm sure a moderator will soon chime in, please don't post the same question in multiple forums. It just confuses everything. | | | | | Joined: Jan 2006 Posts: 13 Junior Member | | Junior Member Joined: Jan 2006 Posts: 13 | Sorry, Didn't know that. I was looking for an answer ASAP, so I could give someone the final word on buying his cab. | | |
