4 members (mick53, 1955 1 Series, Leo, stlcardinalsguy), 77 guests, and 4 robots.
Topics128,180
Posts1,057,156
Members48,464
7
Junior Member
Junior Member
7 Offline
I have a 1/2 ton truck. Can I put a big bolt cab,"I can get a rust free one" on and use 1/2 ton fenders or is the cowel area larger?
The cabs are the same from the little 1/2 tons to the larger 2 tons and everything in between, provided we're talking about an AD series truck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
7
Junior Member
Junior Member
7 Offline
Not sure what the AD series is. I've got a 48 first series.
7
Junior Member
Junior Member
7 Offline
75,
I could go on about what AD refers to but if you do a search for AD truck you will find reams of material. Good luck with your truck and don't forget the pictures!
1951 1 Ton Completed
7
Junior Member
Junior Member
7 Offline
So could a 1948 Thrift master be considered an AD?
An AD series (Advanced Design) truck goes from 47 second series to 55 first series. So, yes, you have an AD series truck. The trucks before the AD's were nicknamed the Art Deco's and the trucks after were called the Task Force trucks. Hope that helps some, welcome to the Stovebolt,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
7
Junior Member
Junior Member
7 Offline
Yes sir! Thanks for the info,"I've got lots of parts missing!"
As I'm sure a moderator will soon chime in, please don't post the same question in multiple forums. It just confuses everything.
1954 GMC De Luxe COE
7
Junior Member
Junior Member
7 Offline
Sorry, Didn't know that. I was looking for an answer ASAP, so I could give someone the final word on buying his cab.
