I removed the small brass plug, removed the felt pad, put a few drops of Kroil in there, worked the speedometer cable back and forth, and it freed up.
From there, I hooked the end of the speedometer cable to a drill, put WD40 in there, spun it around some, until a lot of gunk came out.
I then put the straw of a gun scrubber bottle in the hole, and sprayed as I turned drill until it seemed clean.
After that I let it dry, put a couple drops of gun lube on bearing, soaked felt pad put it back in place, and replaced brass plug.
I reinstalled speedometer and it's totally accurate, matches up just right with phone app GPS.
I'm pretty surprised it started working, it was completely seized up and had been for years.
