2 members (Guitplayer, Lostbuthaulinass), 136 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#145930 03/01/2006 4:08 AM
Junior Member
Junior Member
I have a 48 dump. The registration says it is a 3Ton but the box looks like a fifty dumper 1Ton because of the room between the cab and box for the spare. Is there any way to tell the tonage. And it is possible that someone has changed the box. The box has drop sides and tailgate. It has 20 inch tires and 16 leafs on each spring.
Also where can a fella get some 1 1/2 inch rear wheel cylinders.
Any help is greatly appreciated.
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
several stationary motors
many old tractors
#145931 03/01/2006 4:23 AM
I
I Offline
Well its pretty easy to Id the trucks. You just get your vin number off the cab door post and run it though the "cruncher" in here. Its pretty much acturate. Chevy never made a 3 ton truck. By the discription your give it sounds like a 2 ton. I got rear wheel cylinders from my Napa dealer. They had the master also. Your box sounds more like a modern contractors box. Where you at in Iowa.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#145932 03/01/2006 7:45 PM
I wasn't aware of anything bigger than a 2 ton in '48 from Chevrolet.. in some areas the 'tonnage' rating on the paperwork has less to do with its actual "rating" as it does the 'tax class' the vehicle is in.
It is my understanding that from the factory, the big trucks came with NO BED OR BOX.. so by that line of reasoning, NO box or bed would be 'original'.
Run the numbers of the tag in the drivers side door jam thru the Vin Cruncher and that'll tell you if you have a 1, 1.5 or 2 ton truck.
#145933 03/07/2006 1:38 PM
Junior Member
Junior Member
Turns out that it is a 1 1/2 Ton. That sounds more like it.
Thanks for the help
naylor
36 Chevy 2 dr sedan
48 dumper 1 1/2
64 Chevelle 2 dr HT
51 F1 pick-up
52 F1 pick-up
many old tractors
#145934 03/08/2006 6:03 AM
Most medium-duty trucks were sold cab/chassis style...but GM did offer factory beds in almost every configuration.
Only GMC built trucks for GM larger than 2-tons from 47-55. Chevy didn't get bigger models until they ditched the "boat anchor" low-pressure 216 and 235 models. The high-pressure 235, 261 and V8 engines were needed for heavier loads.
1954 GMC De Luxe COE
