1 members (Hotrod Lincoln),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,130 Posts1,056,717 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Hi guys. Looking for some ideas for a small, safe, functional jack and tool roll for my ‘50 pickup project to keep under the seat. Also, how have you secured the jack to keep it from sliding around? Any ideas welcome. Thanks, Dave.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Dave, a few years ago I lucked into a roll of 3/4” black, soft closed cell foam insulation. A layer on the floor acts as both sound and heat insulation and it’s soft enough that tools sorta nestin and don’t move.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I got a scissor jack, probably a truck one would work best, from a salvage yard. I keep mine and other things in a boot box from a shoe store.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2004 Posts: 29,839 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,839 | Hmmmm- - - - -is that a seat over a hole in the floor- - - - -when the truck hits a mud puddle? ![[elvis] [elvis]](/ubbthreads/images/graemlins/default/elvis.gif) Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dave, do you have room under your seat for a "trolley jack". Its the small "mini" jack like the floor jacks.
I have one that fit down in a rectangular plastic container and keep it on the back of my present 2012 pickup. Since I'm old and weak I also bought me a 18" pull bar with a short extension and correct socket size. I've only had one flat on my truck but not having to fool with a scissor jack or even getting all the stuff out of the cab makes it a lot easier...and the pull bar was great......just giving you ideas.
.On my 37 I have a Freightliner Sprinter jack that I got back in '08 but can't remember what it even looks like. Never had to use it but with limited space behind the bottom seat of my 37 it fit good and is wrapped in some thick polyester fabric along with the tire tool. | | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Thanks for the input, guys… what did our AD trucks come with originally? Was it a mechanical bottle jack? I have the original spare tire carrier on the bed side, so I might try to weld up some kind of bracket on the back of the tire mounting plate to hold a scissor jack? Just an idea…
Achipmonk, I might have room under the seat for that style of jack, but it sounds really heavy. Although easy to use once it’s on the ground!
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dave, I might add that the small "trolley jack" is really not that heavy. I usually man handle it with one hand.
IF you decide to take a look at one you can find them in some stores already in a small plastic carrying case. Good luck on what works best for you. | | | | | Joined: Feb 2004 Posts: 29,839 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,839 | For rigs with a 12 volt electrical system, the small electric scissors jacks are really handy for us old geezers. Nothing like pushing a switch and letting the battery do the work! Jerry
| | | | | Joined: Jul 2008 Posts: 184 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 184 | .My 52 Chevy has the from the factory screw type jack and handle. I just placed a piece of old carpet cut to size. Been 15+ years, no rattle, no movement, no moisture problems. | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | I have a modern bottle jack under my truck seat. It's wrapped in a thin rag to prevent it from moving around.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Good ideas here…thanks to all of you!
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | A very slim, light weight option is your Hagerty Insurance Roadside Assistance card and cell phone. 🤪🤔🫢😂🍻
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | A very slim, light weight option is your Hagerty Insurance Roadside Assistance card and cell phone.🤪🤔🫢😂🍻'  What is Hagerty's distance limit? They are excellent - I have had a policy for many years; but, luckily, I have only had to use it once.
| | | | | Joined: Feb 2008 Posts: 1,123 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,123 | They offer, as I recall, several options. There was a recent change that increased the milage to 100 miles, from 50, for the policy I have. Over the years the years I’ve needed the service twice. Each time the service was exemplary. Their service provider showed up quickly, used a roll back tow truck and showed care for the vehicle both loading and unloading. My guess is other classic vehicle insurance outfits offer comparable products and services. | | | | | Joined: Jul 2022 Posts: 62 'Bolter | | 'Bolter Joined: Jul 2022 Posts: 62 | I use bubble wrap in my Model A and no rattles. 1953 Chevy 3100I have recreated my Dad's old work truck with a 5 window.Photos | | |
