4 members (wilbur53, klhansen, Steelonsteel, Bill Hanlon), 141 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#1456233 06/24/2022 2:03 AM
I need to replace the cowl vent cover gasket on my 1939. Any suggestions on how to remove the old one and install the new?
Rick
1939 Chevrolet Stake Truck
rickmg #1456278 06/24/2022 3:36 PM
I used a gasket scraper that was just the right size to get down in the groove....but something else will work just as well, maybe a screwdriver??
When I replaced the one on my 37 I went back to an original cork type gasket. The first one was a type of rubber and never sealed good.....even with the spring under the dash cut tighter. I may have to replace the cork once more in my life time but the vent presses down into the gasket and seals better.
Just my thoughts.
rickmg #1456582 06/27/2022 1:45 PM
When I did my 40, used a flat bladed screw drive to pop out old gasket. Was pretty rotten. I used a new rubber gasket ( Steele rubber I believe ). It is a little too high / vent cover lid is slightly above surrounding metal. It does seal properly - no leaks.
1940 Chevy KC 1/2-Ton
