6 members (klhansen, Steelonsteel, lumbersawyer, Joe H, JW51, 1 invisible), 86 guests, and 0 robots.
Topics128,051
Posts1,055,764
#145656 02/12/2006 9:48 PM
1 Offline
Hi there. I'm new to these old chevy trucks so help me out. There is a 1954 or 1955 chevy 6400? (GVW 16000) near me. It is $free$ so that is enticing but I just want to know what could be expensive to replace on this truck. I want it to look nice but I would use the dump bed if I take it so it will be a working truck. Engine is free, only two dents on the sheetmetal, hydraulic dump, 13' flat bed, 4-speed went easily through all gears. I know the brakes need attention, the carb needs cleaned from sitting and all the glass is bad. Any tips for anything pertaining to this truck would be appreciated.
Thanks in advance
#145657 02/12/2006 9:52 PM
Glass is easy except for the windshield. Being curved, you have to order it - $200-$300. Does it have the cab corner windows? What's missing? Plenty of places have parts for these. Sounds like you have a good start.
1954 GMC De Luxe COE
#145658 02/12/2006 9:56 PM
There's nothing overly expensive on these trucks, it's the total of all the repairs that add up. Brakes will be the biggest expense unless the engine needs rebuilt, even then, brakes won't be too bad. Parts are still readily available for these trucks so I recommend jumping in with both feet,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#145659 02/12/2006 10:42 PM
Being free, Your're already ahead, in the game.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#145660 02/16/2006 3:57 AM
Like Scott said: Brakes.
Almost anything else you are likely to find used for free if you are patient. Used brake parts are not likely to be any better than what you have.
