| | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 13 New Guy | | New Guy Joined: Feb 2006 Posts: 13 | Hi there. I'm new to these old chevy trucks so help me out. There is a 1954 or 1955 chevy 6400? (GVW 16000) near me. It is $free$ so that is enticing but I just want to know what could be expensive to replace on this truck. I want it to look nice but I would use the dump bed if I take it so it will be a working truck. Engine is free, only two dents on the sheetmetal, hydraulic dump, 13' flat bed, 4-speed went easily through all gears. I know the brakes need attention, the carb needs cleaned from sitting and all the glass is bad. Any tips for anything pertaining to this truck would be appreciated. Thanks in advance | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Glass is easy except for the windshield. Being curved, you have to order it - $200-$300. Does it have the cab corner windows? What's missing? Plenty of places have parts for these. Sounds like you have a good start. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's nothing overly expensive on these trucks, it's the total of all the repairs that add up. Brakes will be the biggest expense unless the engine needs rebuilt, even then, brakes won't be too bad. Parts are still readily available for these trucks so I recommend jumping in with both feet, Scott | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Being free, Your're already ahead, in the game. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Like Scott said: Brakes.
Almost anything else you are likely to find used for free if you are patient. Used brake parts are not likely to be any better than what you have.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
