4 members (Hanks custodian, Otto Skorzeny, Gray_Ghost, 1 invisible), 73 guests, and 2 robots.
Topics128,060
Posts1,055,833
#1454563 06/09/2022 12:38 PM
V
V Offline
So I broke down the Rh5 wheels and tires from my 58 Viking. Sent the 4000 mile 1958 date coded bias ply tires to the tire recycler. The tubes and flaps look to be in really good condition. Can they be reused in another set of tires? Is it worth saving them or should I discard like I did the tires because of their age?
Rich
68 C30 CST dually flatbed dump
58 Viking 6500
viking58 #1454570 06/09/2022 1:43 PM
It's not only dangerous to reuse RH-5's- - - -it's illegal. Destroy them by cutting holes in the wheel parts with a torch, or do whatever it takes to disable them for any future use before scrapping them. You can reuse the flaps, but new tubes in new tires makes a lot of sense. Back when I was selling a lot of tube type tires, most new tires came with a flap included.
viking58 #1454928 06/12/2022 6:18 PM
viking 58 My 48 came to me with 90% rubber on widow makers,I have run it about 20 years that way. To top off tires I use a clip-on air chuck from back at the compressor, so far has worked fine and they seldom need it anyway.
viking58 #1455246 06/15/2022 6:41 PM
I worked with a guy that was in the military in Germany. He had a widow maker on a large military truck that blew apart while driving on the highway! I've reused tubes and flaps in my 3 piece split rims (the ones you can see the lock ring on the out side of the wheel) and they have worked fine for years. But I would agree the true widow maker wheels should not be used!
viking58 #1455291 06/16/2022 1:26 AM
One sneaky trick when installing an inner tube- - -new or used- - - -is to dust the inside of the tire with talcum powder. It helps any wrinkles in the tube smooth out as the tire is inflated.
viking58 #1455304 06/16/2022 3:10 AM
Crusing in the Passing Lane
I have 2 containers of talcum powder just for that, really helps.
Ed
viking58 #1455305 06/16/2022 3:20 AM
... but may cause ovarian cancer ...
viking58 #1455307 06/16/2022 3:36 AM
only if you have ovaries.....
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Bill Hanlon #1455615 06/19/2022 1:44 PM
Bill Hanlon Keep my ovaries way back...in fact clear in the house,however she did help check toe-in !!
viking58 #1455621 06/19/2022 4:16 PM
She sounds like a keeper.
Bill Hanlon #1455818 06/21/2022 11:36 AM
Bill Hanlon Had her 50 years this summer,when we were young put her in the old 52 with no door handle on her side,got in accelerator stuck wide open,have not seen fear in her eyes like that since !!! We've had about 30 old AD's she liked the 54 Hydramatic the best great to haul flowers.
Bill Hanlon #1455877 06/21/2022 7:37 PM
Bill Hanlon Had her for 50 years this summer !!
