| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Hey guys, I hate asking stupid questions, but I'm having a hard time figuring out how to remove the rear leafspring eye bolts. The fronts were no problem, but now it's time to replace the rear springs. any info would be a big help. Please get back to me at ; [email protected]Thanks, Rick. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy topcat, could you tell us what year and what size truck please. | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Most older trucks have the shackles in back, come apart easy, and then a single "pin" bolt at front eye. Usually have a thin nut on one end, then the pin bolt will unscrew from mount. They are fine threads, and may be tight, use big sockets! Look for ovaled pins, worn bushings in the frame mount. Most spring shops have these for better prices than mail-order places. Get pins, bushings and nuts. They can push the old bushing out of spring eyes, and install new ones for reasonable money. Otherwise, you will be beating and chiseling awhile to get them out at home.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you are talking about the U-bolts holding the axle to the springs, cut those with a torch. It is not reccomended to reuse them.
If you are trying to remove the springs from the frame, then if it is a larger truck, one ton and up I think, it may have a small lock pin to remove, and then a big punch and a hammer will drive the large pivot pin out. Or a slide hammer with an adapter for the grease fitting hole works too. My 52 one ton is like this.. | | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | No need to use a slide hammer to pull the pins out.
The spring mounts welded to the 6400 frame have an access hole to drive the pins out from the inside out. All you need is a drift & a hammer after you remove the set pin. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I drove mine out, but the manual does show the slide hammer I believe. | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Thanks for all the help guys, I really appreciate it. The truck is a '53 6400 2 ton(sorry, I should have included that). I did see the acces holes in the frame, so driving them out makes sense.
So I know what to expect, what kind of pin is the set pin?
Thanks again, RICK | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy topcat, the "set pin" is a tappered pin with a flat ground on one side to interlock with the spring pin, just remove the nut and drive them out. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Topcat...
Just throwing in my $.02...I am in the process of putting all new hardware on my springs for my 46... SAVE EVERYTHING until you find new. I tossed the 11/16th fine thread nuts that held the main eye bolt in...I did not know they were hard to get items...I have them coming now, but had to order them from Colorado...I hope they turn out to be the right ones... | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | Thanks Shop Shark, good advice for any project. I'd like to know the name of the place you bought your hardware from, I will need new eye bolts for my '53, plus other stuff. Haven't tried a local spring shop yet, but the local shops are only so so. No old shops in the area. The nearest one is in Orlando (1 hr away) Rick | | |
