5 members (IHPWR, Peggy M, 55shaker, 1955 1 Series, 1 invisible), 78 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
I cant seem to find the rod that goes thru the center of the hood hinge on my 38 1.5 ton.. does anyone sell that or go to hardware store? What size is it?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
Other pro's may have the answer but I would not hesitate to go to Lowes or Ace Hardware, or such, and buy a rod. you may want to try "size" it using wooden dowels or do some measuring if you have a set of dial indicators.
Crusing in the Passing Lane
Probably .250” which is common, easy to measure. My local hardware store has that, or can order it. SS is handy, doesn’t rust, however, it can gall, so make sure it is not too tight fit, lube with anti sieze upon assembly which will make a mess. Grind a bullet shape on the end inserting first to line up each hinge piece.
Others have used Teflon rod with success, no lube required.
Ed
I used stainless steel rod. Been a while but I am thinking 3/16”
1940 Chevy KC 1/2-Ton
