5 members (60steve, Alex52, Gdads51, 2 invisible),
76
0
Mod | | | Forums66 Topics128,212 Posts1,057,465 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | I cant seem to find the rod that goes thru the center of the hood hinge on my 38 1.5 ton.. does anyone sell that or go to hardware store? What size is it?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Other pro's may have the answer but I would not hesitate to go to Lowes or Ace Hardware, or such, and buy a rod. you may want to try "size" it using wooden dowels or do some measuring if you have a set of dial indicators. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Probably .250” which is common, easy to measure. My local hardware store has that, or can order it. SS is handy, doesn’t rust, however, it can gall, so make sure it is not too tight fit, lube with anti sieze upon assembly which will make a mess. Grind a bullet shape on the end inserting first to line up each hinge piece.
Others have used Teflon rod with success, no lube required.
Ed
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used stainless steel rod. Been a while but I am thinking 3/16” | | |
