7 members (Donf, King Kielbasa, jmoore, Gdads51, cmayna, 2-Ton, 1 invisible), 85 guests, and 1 robot.
Topics128,169
Posts1,057,041
Members48,458
Socket Breaker
Socket Breaker
how many tools does it take... to do a little wiring?
ohwell
grin
-Woog
Insomniac
Insomniac
It takes a least one more than you originally thought. You find this out while lying on your back under the truck.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Every job, automotive and otherwise, takes just about every tool you own.
1950 Chevrolet 3100 (Ol' Roy)
You always need a tool that you cant find (at the moment), so run to the FLAPs, to get another one, and the one you were looking for magically appears.
Another quality post.
Real Trucks Rattle
The critical tool is always the one you lay down.......and then can't find. So many times,,,,,,so many.
RonR
RonR
1970 340 Duster
1964 CJ5
J Online: Content
Answer: all of them.
1951 3100
W Online: Content
It's a pretty lousy project that doesn't require buying a new tool.
Socket Breaker
Socket Breaker
You folks are cracking me up.
You are all correct... and been there before.
-Woog
J Online: Content
Wiring jobs take me at least 3 tools because of the crappy tools I have. One cutter/stripper/crimper has the “best” (still lousy) cutter. One has the “best” (awful) stripper, and the other has the “best” crimper.
1951 3100
For working under the dash on short wires, a good friend sent me gift : KNIPEX End-Type Wire Stripper.
This would have saved a lot of creative cursing under my 1954 dash last week. My Suburban has several 6v accessories: electric-wipers, original steering-column-mounted turns-signals, original-style/size radio/seaker, and original deluxe Air-Flow Heater.
I had wired the ignition switch incorrectly and my good friend did not approve - I said "you volunteered to crawl under the dash to correct/re-route that rat's ness of wiring".
The swear words were creative and they were effusively used; and, the fingers and knuckles were severely abused and sore.
The KNIPEX 11-160 End-Type Wire Stripper would have helped a lot.
Socket Breaker
Socket Breaker
Ooooh, I may have to invest in one of those TC, thanks for the tip.
-Woog
JW51 The best crimper I know of is Thomas & Betts pro tool,Ideal cutter and stripper also pro. Klein is same pro stuff,Greenlee is hi quality tooling. Have burned thru several pairs of all the above. Also use an old roll of dutch boy rosin core solder.
