| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | The two speed on my 54 6400 is leaking at the point where the driveshaft connects to it. I would like to fix this, but I'm afraid that if I take it apart, I will not be able to find seals etc.
I have a 1953 truck, but the rear end is from an earlier model. I don't know exactly what year. The one I have has only one brake cylinder, whereas the later models have two. I think it is probably a 48 to 50, but I'm not certain.
The only marks I can find on the two speed is an S on the filler plug.
Has anyone else had this problem? Do you have any idea where I could get the parts to fix it?
I had a very hard time finding seals and bearings for the wheels when I was working on the brakes. I was not able to find brake cylinders, and finally had them sleeved. If I take it apart, and can't find parts to repair it, I will really be up the creek without a paddle.
I don't know what the seal looks like, but I assume it must be something on the order of the seal that goes in the wheels, since it must fit over a shaft.
Any suggestions would be appreciated. Thanks, Allen | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that'd be the pinion seal, a common problem - try to find one before you take it apart, likely to be the same for a lot of years
Bill | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Does anyone know of any old truck suppliers that might have one. The ones I know about don't carry much of anything for the big trucks. If I take it apart and take the old one to someone who carries a lot of seals, there is a fair chance they may be able to find one by taking the measurements, but if they can not, then I have ruined the old one, and am worse off than I was before I started. Thanks Allen | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Try Napa, they had the seals for my 1 ton's full floating rear axle. The same seals were used for like 30 years. A big truck parts house probably also has them. | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | These seals are out there. The same seal was used on '41-'55.1 2-speed rears. Try your local Chevy dealer and ask for part #3651493. They might locate one through the dealer network. You could also try part number searches at Partsvoice or Collector Auto Supply . If you can get the pinion flange off, you might be able to see the part numbers on the seal for cross referencing.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | Thanks for the information. I never heard of either Partsvoice, or Collector Auto Supply, but I'm glad to know they are out there. I'll also try the Chevy dealer and NAPA now that I have a part number. Thanks Allen | | | | | Joined: Aug 2005 Posts: 212 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 212 | I took the part number to an Advance Auto store yesterday, and by using their parts interchange system, the located one. It was a special order item, and will take about one week to get here, but it didn't seem to be a problem getting it.
Curt: Thanks for the part number. I can't imagine how you had it so readily available, but that was what did the trick. Without that I probably would not have been able to find it.
Thanks, Allen | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Allen, Glad I could help. This online parts manual is a big help. Thanks to Keith Hardy.
