7 members (UtahYork, k2handyman, TUTS 59, Otto Skorzeny, 55shaker, TooMany2count, 1 invisible), 68 guests, and 3 robots.
Topics128,031
Posts1,055,433
Members48,422
#145368 01/11/2006 5:50 AM
The two speed on my 54 6400 is leaking at the point where the driveshaft connects to it. I would like to fix this, but I'm afraid that if I take it apart, I will not be able to find seals etc.
I have a 1953 truck, but the rear end is from an earlier model. I don't know exactly what year. The one I have has only one brake cylinder, whereas the later models have two. I think it is probably a 48 to 50, but I'm not certain.
The only marks I can find on the two speed is an S on the filler plug.
Has anyone else had this problem? Do you have any idea where I could get the parts to fix it?
I had a very hard time finding seals and bearings for the wheels when I was working on the brakes. I was not able to find brake cylinders, and finally had them sleeved. If I take it apart, and can't find parts to repair it, I will really be up the creek without a paddle.
I don't know what the seal looks like, but I assume it must be something on the order of the seal that goes in the wheels, since it must fit over a shaft.
Any suggestions would be appreciated. Thanks, Allen
#145369 01/11/2006 6:05 AM
that'd be the pinion seal, a common problem - try to find one before you take it apart, likely to be the same for a lot of years
#145370 01/11/2006 6:32 AM
Does anyone know of any old truck suppliers that might have one. The ones I know about don't carry much of anything for the big trucks. If I take it apart and take the old one to someone who carries a lot of seals, there is a fair chance they may be able to find one by taking the measurements, but if they can not, then I have ruined the old one, and am worse off than I was before I started. Thanks Allen
#145371 01/11/2006 7:23 AM
Try Napa, they had the seals for my 1 ton's full floating rear axle. The same seals were used for like 30 years. A big truck parts house probably also has them.
#145372 01/11/2006 7:55 AM
X
X Offline
These seals are out there. The same seal was used on '41-'55.1 2-speed rears. Try your local Chevy dealer and ask for part #3651493. They might locate one through the dealer network. You could also try part number searches at Partsvoice or Collector Auto Supply .
If you can get the pinion flange off, you might be able to see the part numbers on the seal for cross referencing.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#145373 01/11/2006 1:47 PM
Thanks for the information. I never heard of either Partsvoice, or Collector Auto Supply, but I'm glad to know they are out there. I'll also try the Chevy dealer and NAPA now that I have a part number. Thanks Allen
#145374 01/12/2006 5:03 PM
I took the part number to an Advance Auto store yesterday, and by using their parts interchange system, the located one. It was a special order item, and will take about one week to get here, but it didn't seem to be a problem getting it.
Curt: Thanks for the part number. I can't imagine how you had it so readily available, but that was what did the trick. Without that I probably would not have been able to find it.
Thanks, Allen
#145375 01/13/2006 7:05 AM
X
X Offline
Allen,
Glad I could help. This online parts manual is a big help. Thanks to Keith Hardy.
Curt
