I'm looking for the rear mount brake for my 49, too! You will need the whole back plate off the trans, as it has the cast mounts on it for the brake bands. Mine had cables, whacked off by someone, and now a diff rear than stock. The trans mount is so much nicer. Those floor pans can be gotten from most vendors. They are even offering half floors with toebaord part attached now. OR, can get either side and toe board all seperate too. A new source for such parts, cheaper than most is Raybuck's. Try
www.raybuck.com no S in it. Not much on site, but I got catalog showing the parts. Most tins are made by one outfit, just prices are different. Bow Tie Bits is good place. Chevs of the 40s now has the most available tin I have ever seen, can almost make a whole new cab with all their parts. They don't have roof or cab back window area, but everything else, including the back of can and below gas tank and accross the front cowl at windsheild. First I have seen on those parts from anyone. Be sitting down when they give you their prices!!
