| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | Has anyone been successful in matching the maroon-ish color for the metal trim around the door panels with an off the shelf rattle can color? I'm going to head down to FLAPS to see what they might have in a Duplicolor spray can. I could go to the paint store and pick something from their chip books, and have them mix me up a rattle can, but if I can get close enough with something off the shelf, it would be much cheaper than a custom color rattle can at over $35. It's the only thing I can find on the truck that needs that color. And being a cheapskate .......  Thanks
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | Well my search for matching the marooon color remaining on the metal trim was a bust. But I dug out the door panels and they're not maroon, but are brown. So I'm headed back to find a paint that matches them (and the headliner I bought.) Should be easier, as there are a number of browns available.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | If anyone cares,  I found a can of Rustoleum Leather Brown that's an adequate match. The door panels I got were from Jim Carter. They don't carry the maroon ones, but do have vinyl in that color, but that's too fancy for a base level trim truck like mine. I have no idea what color the original panels were, cause they're long gone. I only have two pictures of the interior showing the door panels and they're too dark to tell the color. But the metal trim was definitely maroon, probably pretty close to the seat upholstery. They're going to be brown now (don't tell the purists.  )
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | klhansen What brand was your FLAPS that does those spray cans ?? Never saw that around here. Have several of those door panel trim edges,need to make some up like yours!! | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | klhansen Bought some interior paint from Carter's ,is brown with a rose hint color to it. That brown would be OK too. doesn't have to be perfect for this one . | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | What about powder coating vs rattel paint? | | | | | Joined: May 2015 Posts: 11,080 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,080 | klhansen What brand was your FLAPS that does those spray cans ?? Most FLAPS don't carry Rustoleum. I got it at Lowes. Home Depot probably carries it as well, but I try not to shop there.
