| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Anyone had experience with paintless dent repair on the thicker metal our trucks are made of?
| | | | | Joined: Mar 2014 Posts: 4,484 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,484 | A friend told me it didn't work and that the dents had to be fixed a la old style...some with a small hole drilled and a slide hammer with screw tip to pull them out and body filler to smooth. Some of those areas can't be fixed any other way. Sorry to hear that.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,783 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,783 | If there's an access hole close to a dent that can't be accessed directly with a hammer and dolly, use something called a "pick tool" to push most of the dent up close to level where some careful massaging with a smooth faced body hammer can be used to minimize the distortion. Be aware that a dent of more than a very small size will stretch the metal, making it difficult to put it back into its original shape without "oil canning"- - - -popping in and out with a slight push on the dented area. Here's one example of a pick tool. Most well-equipped body workers would have an assortment of lengths and shapes, and sometimes it was necessary to drill a hole from the back side in double pamel sections close to a dent to use the tools. They're not just bent pieces of round stock- - -the good ones are spring steel. https://www.ebay.com/itm/403531763396?Like a lot of other skilled trades, body workers who actually know how to straighten dents and metal finish their work are a dying breed! Now it's "cut, spot weld, and slap on the Bondo"! Jerry
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | I tried paintless dent repair on some of the dents in double wall structure. Didn't work worth a darn. The glue-on tabs wouldn't stay in place long enough to move the metal. I finally borrowed a stud gun and pulled out a few dents that way. My opinion - don't bother trying paintless dent repair on anything but the tinfoil they make modern cars with.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I watched a guy who knew what he was doing make some amazing paintless hail damage repairs on a very fine paint job. Fascinating to see. I would recommend you look for a guy who does it full time. They generally will come to you. I guy who does it all the time will let you know about if the steel is too thick. I'm thinking that if the hail dented it, it ain't as thick as you think. These round trucks get a lot of their stability from being round. Kind of like how an egg shell, as fragile as the shell material is, holds up pretty good for what it is.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | considering just hail damage my local shop had a fellow come work in their shop after a pretty rough hail storm. My wifes car took a beating but not enough dents to total or do panel replacement. The "guy" even dropped the headliner to get to the dents. I was totally shocked at the job done. Drove the car for several years and you could never tell where a hail hit it. | | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | Check out some videos,I watched a few a year or two ago it is interesting .The tools are expensive and I remember that they used a line light that showed lines on the vehicle and when the dent was pushed out the lines evened out indicating the dent was out. | | | | | Joined: May 2005 Posts: 281 'Bolter | | 'Bolter Joined: May 2005 Posts: 281 | I also had a good experience with a knowledgeable and skilled paintless dent repair shop. My wife's Cadillac, 1995 DeVille, suffered hail damage on nearly every panel. Reynolds collision center in Oklahoma City repaired it. This was about 6-7 years ago. I sold the car earlier this year and I was never able to find any evidence that there had been hail damage after they finished. It wasn't cheap, $750 as I recall, but the quality repair was excellent.
Mark | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Kevinski, I have watched several videos and am amazed at the results they get.
Mark, I will check into Reynolds Collision Center. So far most don’t want to do “older vehicles” due to the thicker metal being harder to massage.
