0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Ok guys need ya' to school me on how to adjust the rear bracks on my 53 6400.
Here's the background. Over thanksgiving I figured I'd try to get the brakes working on this truck so far I've not been too worried about them just driving it around the farm and in the fields at the farm, as the handbrake stops it fine, and the regular brakes work consistently after 4 pumps. The truck hasn't lost any fluid since we got it. We went ahead and bled the system at each wheel as we figured it was just some air in the lines. It had a little but all of them bled out fairly quickly and none of the bleeder screws were stuck. Near as we could figure maybe the brakes hadn't been adjusted in a very long time and it was just taking 4 pumps to get them out to where they caught so I adjusted the fronts via the normal screwdriver in the slot method (they adjusted a long way out but then caught good). But I couldn't figure out how to adjust the duals in the back. I'm new to the big trucks so this is prob. simple and I just haven't run across it yet.
I did pull the drum on the front left and the pads look like they have alot of life left so I'm hoping this will be the quick fix.
Also the truck has a hydrovac and I've got no idea how it works or if it's working.
Thanks, MONGO | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There are 2 slots on each backing plate to adjust the brakes. I can,t remember which way to turn them but I think you pull the soon towards the axle. You should hear a suction noise from the hydrovac when you apply the brakes & the braking action should be strong if it,s working right. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Some GMC's and Fords have a big cam bolt top and bottom on back plate. Loosen lock nut, adjust bolt/cam, tighten lock nut. There will be two seperate cyls to adjust on these. Get a brake spoon, much better than "driver" and has odd angles, easier to work with. Don't be suprised if you don't have to remove drum and work the adjusters some to get unrusted and moving. Adjust way out while drum's off, just enough to allow drum to slide back on. Power booster will feel just like modern power brakes, plus when you let off, you should here a hiss or such at filter which is behind the rear seat in corner of cab. I drove mine w/out working booster for 5 years, just have to push a little harder on pedal. One day, the thing just started working after sitting half the winter, not sure why? Was much nicer to drive with a load after that, for sure.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | I wondered what that filter was for back by the gas tank didn't make much sense to have gas tank vented into the cab but I haven't removed the tank yet to get it cleaned so didn't relize what it was hooked too. starting to wonder if maybe my supposed 4400 is a little heavier | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | kb3csw,
My 4400 has a hydrovac with the vent/breather behind the seat. Standard equipment on this size truck.
Stuart | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | | | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | Grumpy, great info. I just got a 49-6400 and it has no sign of any brakes. Looks like another total brake overhaul on this one, I doubt that the Flintstone method would work on this big beast-Oh and no emergency brake either. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The easyest way I have found to check the Hydrovac is to push on the brake pedal and then start the engine. If it is working you will feel the pedal fade down a little bit as the vacuum increases. Don't forget to add a small amount of 10w oil (3 in 1 oil should work also) to the Hydrovac canister from time to time. This keeps the leather seal soft. See the repair manual for instructions. The breather cap found inside the cab is connected to the atmospheric side of the hydrovac canister. They were put inside the cab to help keep dirt from getting sucked in. My BIG trucks have this line connected directly to the clean air side of the engine Oil Bath Air Filter. Mike  | | |
