0 members (), 106 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
Finally putting my '52 4100 dump on the road. I need to know the ballpark unladden weight for the DMV. Any info out there in Stovebolt land? It is a Base 4100 with a 8' Gallion dump body with no cab shield if this helps.
1942 Chevy G7104 1.5 ton 4x4
1946 Willys CJ-2A
You can look up the weight of a 4100 with no bed in a restoration pack. Its heavy, but I think less than 5,000 pounds.
But I have no idea how much more that dump bed and hoist add. A lot I'm sure...
Mine's got a 12 foot bed and it weighs around 6000 pounds, give or take a few hundred,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
My 4400 loadmaster with a 12 ft. bed with a hoist weighs in at 7982lbs. Thats with me in the driver seat. Oh yea , I weigh in at 220...
The standard 8' 3-4 yd contractors dump body weighs about 1400 lbs. The twin arm hoist complete weights about 725 installed. So 2100 lbs is a good estimate of the unladen body/hoist weight.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
So is 7,000 pounds a good ballpark guess for his truck?
If Fatboy's truck is nearly 8000, would this truck, minus Fatboy and 4 foot of truck, be a thousand pounds lighter? It feels right to me, but I'm just guessing.
I think I'd want to know if there is a good reason to be over or under some figure, and then see if I could legitimately call it over or under that figure...
V
V Offline
If you really want to know, go to a big grain elevator in the country somewhere. A business grain elevator, not a farmer that has a grain silo. They have trucks scales there. Probably do it for free, or close to free.
Most old medium trucks I've had are 6500 to 7000 with a bed and empty. Go to a gravel pit and weigh. Sometimes there is a small charge to get a written or printed out paper for proof. Is this for plates? I could run 11,000 on mine, if I didn't carry much. If I wanted to be hauling gravel, sand or dirt, I got the 16,000 lb plates. Even then one time I had close to 18,000 with a load of gravel once. Truck could barely handle it, took low gear to get out of pit area up the hill! This is all in a 54 two ton truck with 12ft dumping flatbed.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
Thanks for the replies. I was guessing it around 6000-6500 empty, and that is what I'm putting down. I cant drive it anywhere to weigh it, no plates yet.
1946 Willys CJ-2A
