4 members (wilbur53, TrknGMC, Steelonsteel, UtahYork), 117 guests, and 0 robots.
Topics128,113
Posts1,056,616
Members48,450
#1450183 05/01/2022 10:33 PM
I don't know where to ask this. My fuel tank on my 54 is an aftermarket aluminum 20-gallon. I have never been able to put more than 15 gallons in it in the last 16 years. I have an electric backup fuel pump and I am thinking of unhooking and running it dry into a large gas can and see how much it will hold.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Leo Offline
Moderator
Moderator
What exactly are you asking?
If your question is should you do it ..... why not? The results will ease your mind.
WE b OLD #1450256 05/02/2022 11:27 AM
Ex Hall Monitor
Ex Hall Monitor
You say you've not been able to put more than 15 gallons in it. What metric are you using to tell you it's empty? If you're using the gas gauge and filling when it says empty your float may not be at the bottom of the tank. You might have another 5 gallons that the float doesn't see. Run it until you're at empty then stick a siphon hose in the tank and see how much, if any, is still there.
WE b OLD #1450261 05/02/2022 12:48 PM
Right after I got the '51 on the road in a dependable fashion I threw a full 5 gallon jug of gas in the back and just went about my normal driving. It seemed like it took forever to run the tank empty. When it did run dry (after giving plenty of warning it was about to) it was a simple matter to put the emergency gas in, saving a little to prime the carb and crank her up. Then drive to the gas station with the concrete knowledge of where empty on the gauge truly was (it's right after the gauge hand hits the lower leg of E on my truck).
RonR
RonR
1970 340 Duster
1964 CJ5
Curmudgeon
Curmudgeon
You may not want it to be full. The original tank gas cap is not pressurized.
Gas station tanks may be underground so the gas is at ground temperature.
Here in the South, where temps usually hit 90 in the summer, that cool gas heats and expands a lot.
On original trucks the cab heats up like a toaster oven in the sun and so does the gas in the tank behind the seat.
Gas can force it's way past the gas cap seal and ruin a nice paintjob.
Back in those days you had to remember not to "filler up".
Or, park it on a slope with the passenger side down.
1952 Chevy Pickup Truck
Insomniac
Insomniac
Don't do a "filler up" on modern cars either. You can mess up the EVAP system by overfilling.
Since most of us now use a credit or debit card to pay for gas there's no need to top it up to the next highest dollar.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Ron,
You need to live closer to the edge. Drive your baby till she's out of gas. I'll bet she'll take 20 gallons then.
I run mine until the needle quits wiggling from the sloshing gas. I know that I have 20 miles until I need to be next to a gas pump.
Edgy Carl
I would just figure the volume using the basic L X W X H. There are 7.48 gallons to the cubic foot.
WE b OLD #1451076 05/09/2022 12:11 AM
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
Yep. In 1990 I bought a 29 Ford in college. Went home next summer and gas forced itself out and dripped a nice hole into my parents newly paved driveway.
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
