3 members (Opelika Tom, 2 invisible),
95
0
Mod | | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I have a fleet of 55-57 1.5 and 2 ton trucks and would like to know if anybody knows what I should be searching for if I want to eliminate the 20' split rims and put 22.5' on the 2 tons and 19.5' on the 1.5 ton trucks. Any later model trucks I might find in the wrecking yards that would trade out would be good. My trucks have the 5 bolt front pattern with the ten bolt rear and I have 1 6500 with the 6 bolt pattern front and rear. Thanks for any advice. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | tri5, I'm interested, too...I'd like to put modern rims on my dad's '51 2-ton GMC. The front wheels should actually be 10-lugs, with an adapter plate covering the 5 unused holes. | | | | | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | ever try looking into Budd Wheels.....I don't know either, but it's worth a try----- | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I checked the fitment link on one of those Alcoa links. It said the following:
NOTE Specify only hubs that are designed for aluminum hub piloted wheels. Hubs designed for steel hub-piloted wheels do not have sufficient pilot length to locate dualed aluminum wheels. Because of the pilot length, Alcoa 16x6 and 16x6.5 aluminum wheels must be dualed with an inner steel wheel. Stud lengths must also be sufficient to clamp aluminum wheels. Before mounting hub-piloted wheels, generously coat the wheel pilot or hub pads with a non-water-based lubricant, such as Freylube or equivalent, to minimize corrosion build up. DO NOT LUBRICATE THE FACE OF THE WHEEL OR THE HUB.
I don't know anything about the pilot length on these old trucks. Does anyone know the size and length of the pilot portion of the hub?
I'd love to put these wheels on one of my old trucks.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Those Alcoa wheels would look great on the 350, but I don't know if my dad would go for it or not. The steels would probably be more up his alley.
Will the 19.5" wheels clear the AD brake drums? | | | | | Joined: Mar 2005 Posts: 27 Apprentice | | Apprentice Joined: Mar 2005 Posts: 27 | "Because of the pilot length, Alcoa 16x6 and 16x6.5 aluminum wheels must be dualed with an inner steel wheel."
That's pretty typical. Why pay for six expensive aluminum wheels when only four show?
Joe Padavano
| | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | My thinking is that if you paint up your old bolt and want nice wheels and can get 19.5 or 22.5 wheels and wheel simulators for less than the Alcoa wheels. | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | GMC Panel,
The old (1950's & '60s) 8 x 19.5 rims will clear your AD drums...a goodfriend has a '51 3800 dump with eight-lugh wheels and has run both 18" and 19,5" rims, depending on which tires are available.
One set of his 19.5's are tubeless are are really tough to change tires on w/o a tire machine...on the other-hand, they will support tubeless and radial tires...
I've seen later Chevy/GMC 1.5- 2-ton trucks that look like they've been outiftted with 19.5" rims on a chassis that once ran 20 "...the wheels/tires look a little skimpy on the big trucks...
One time I went to the local chain of truck tire centers (big regional Mom'n'Pop: Jack Williams, for those in the Northeast) and talked to one of their fleet guys...this was about new rims to use on the six-spoke cast demountables on my '34 International C-35...I believe he had a Dayton Wheel catalog and we did find some new rim sections that would work ...they'd probably also have listings/specs on which wheels might work on an AD big bolt...???
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
