0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | thanks to all for the information on the tire wheel thing. i was able to find an old timer to change my 7 tires/rims. i got 7 new ones from nebraska tire and the rims were sandblasted, painted and reinstalled with new tubes and flaps. my question is should i add a puncture proof slime to the tubes? it was somewhat difficult to get them changed and if i could prevent any future flats, that would seem like a good idea. what are the risks involved in that stuff? | | | | | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | It is just my opinion, but Slime would merely cover up a problem, possibly causing major tire damage over the long haul.
I don't remember your previous thread enough to know the tire size you have, but it is pretty rare for the larger truck tires to have flats. I have been running my 3800 with 6 ply 18 inch tires on it since 1997 and have yet to have a flat tire. For most of that time it has been my primary vehicle.
Remember, just my opinion.
Word hard, play harder, enjoy life!
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Homer, just my opinion as well but I'd stay clear of that stuff on a vehicle. The guys who have to fix tires that have that stuff tell me they want no part of it. I only use if for my wheelbarrow and hand truck. | | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | my tires are the regular 20 inch ones. the truck is a 46 ton and a half with 10 bolt rims. my concern is that i will not be able to fix a flat in the future. the gentleman who changed them this time is in his 70's. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you DO put that junk in them, then you won't find anyone to fix them. That stuff is supposed to coat the inside if your tire not the inside of a tube. Please, don't use that gimmick stuff, you'll wish you'ld never heard of the stuff if you do, Scott
P.S. Where are you from, I know plenty of places that will service truck tires in my parts, me included. | | | | | Joined: Jan 2004 Posts: 30 Junior Member | | Junior Member Joined: Jan 2004 Posts: 30 | i am located in the upper peninsula of michigan. sparcely populated and only a couple of tire places. hopefully it will be a moot point as the tubes, flaps and tires are all new. thanks again | | | | | Joined: Oct 2005 Posts: 37 Junior Member | | Junior Member Joined: Oct 2005 Posts: 37 | 48bigtrucks, they make slime for tubed and tubeless tires, it is not that difficult to deal with if you do get a flat (the hole will be pretty big so you will probly be replacing anyway) It is that fix a flat that is the real bad one. Like windy said though, you will probably not have many flats anyhow on 20s
1951 6400 1954 6100 dump 2 1962 IHC scouts
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | Just a note the slime will freazze in the up of mic. and bee a frozzen lump in your tube and tire
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
