1 members (NJC), 138 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1449264 04/24/2022 11:34 PM
I bought a 1951 3100 starting to do a rebuild and was checking the engine.
I was told it was a 216 but having a hard time checking the engine serial numbers to verify.
The stamp on the block is FI20IJ0 any idea if this is a 216.
Curmudgeon
Curmudgeon
F = Flint assembly plant
I2 = Calendar month 12 = December
0I = Day = 01
J0 = Check again, this may be JC
JC = Light truck with RPO 227
The above applies to 1958 to 1962 years.
Either a 235 or 261 engine (captain's bar).
Get the code behind the starter to determine year of manufacture.
Picture of engine helpful if you need more info.
My research shows the "JC" designation as being for a 235 only with 3-speed trans and HD Clutch installed in a 1958/59 4000 series (1-1/2 ton truck) or in the 3000 series with RPO-227 (HD Clutch). Then in 1960 it was only available in the 1/2 to 1 ton trucks (C10, C20 & C30 and K10 & K20) when ordered with RPO-227 (HD Clutch). For 1961 and 62 they added the 40 series back into the mix (C10, C20, C30 & C40 and K10 & K20). I didn't find any mention of "JC" being a 261.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
