| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2021 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2021 Posts: 27 | I bought a 1951 3100 starting to do a rebuild and was checking the engine. I was told it was a 216 but having a hard time checking the engine serial numbers to verify.
The stamp on the block is FI20IJ0 any idea if this is a 216. | | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | F = Flint assembly plant I2 = Calendar month 12 = December 0I = Day = 01 J0 = Check again, this may be JC JC = Light truck with RPO 227 The above applies to 1958 to 1962 years. Either a 235 or 261 engine (captain's bar). Get the code behind the starter to determine year of manufacture.
Picture of engine helpful if you need more info.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My research shows the "JC" designation as being for a 235 only with 3-speed trans and HD Clutch installed in a 1958/59 4000 series (1-1/2 ton truck) or in the 3000 series with RPO-227 (HD Clutch). Then in 1960 it was only available in the 1/2 to 1 ton trucks (C10, C20 & C30 and K10 & K20) when ordered with RPO-227 (HD Clutch). For 1961 and 62 they added the 40 series back into the mix (C10, C20, C30 & C40 and K10 & K20). I didn't find any mention of "JC" being a 261. Mike B  | | |
