2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#1448952 04/21/2022 8:43 PM
This could be a silly question but I was working on putting the door handle on my 1950 panel rear door and the handle spins free from the shaft on the handle. Was this connection originally soldered or has a pin sheared that I cannot see? I've tried to attach picture of where its spinning. [img]https://www.stovebolt.com/ubbthread...ame/16505736664956452955897044324560.jpg[/img]
I think they were originally pressed in...but I've seen quite a few that owner's have drilled and pinned.
We cant get new rear handles but there is a tech tip here in how to modify a side door handle for the rear. Its a simple process .....or I couldn't have did it. smile
Welcome to Stovebolt.
Okay thank you, I did end up just drilling it and pinning it. Seems to be a good repair that will last a while. I did look at tech tip for modified side handle also thank you for the suggestion,
