| | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2022 Posts: 6 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 6 | This could be a silly question but I was working on putting the door handle on my 1950 panel rear door and the handle spins free from the shaft on the handle. Was this connection originally soldered or has a pin sheared that I cannot see? I've tried to attach picture of where its spinning. [img] https://www.stovebolt.com/ubbthread...ame/16505736664956452955897044324560.jpg[/img] | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think they were originally pressed in...but I've seen quite a few that owner's have drilled and pinned. We cant get new rear handles but there is a tech tip here in how to modify a side door handle for the rear. Its a simple process .....or I couldn't have did it.  Welcome to Stovebolt. | | | | | Joined: Jan 2022 Posts: 6 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 6 | Okay thank you, I did end up just drilling it and pinning it. Seems to be a good repair that will last a while. I did look at tech tip for modified side handle also thank you for the suggestion, | | |
