3 members (Otto Skorzeny, Youngin' Tut 59, delky), 114 guests, and 4 robots.
Topics128,186
Posts1,057,302
Members48,467
Tomorrow I am going to meet someone who has a '54 3100 series which has been sitting since 2003. He wants to restore it but first wants to get it back up and running. What is the best priority list for him to follow. Yes, change all fluids, check brakes, etc. I'm concerned about having new oil at the valve train when he cranks the motor over for the first time. Yes for turning the motor over by hand just to make sure nothing is bound up. So, if someone has a basic TODO list of what to look at, change, etc, that would be very helpful.
Craig
Craig
Craig, check the Tech Tips. There is a very good one there for the taking!
#1 on my list is to avoid using any gas whatsoever via the gas tank. Use a small boat tank. Leave the priming bulb on it to prime the fuel pump.
Crusing in the Passing Lane
Oil all the valves, then tap each one with a rubber hammer or 2 x 4 to make sure they are not stuck, BEFORE turning the engine over by hand.
Ed
Wouldn't hurt to also pour a little ATF in all the cylinders and let it sit a while before turning the engine over. Leave the plugs out when you first turn it over to blow the ATF back out.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Martin,
Which particular Tech Tip were you referring to? There are so many tips but haven't found one yet which is a semi simple list for one to use that covers many of the "todo"'s.
52Carl, Ed & Rich - Thanks for the very valuable suggestions. Will pass them along.
Will be going to see the rig today.
Craig
cmayna The main thing is to be sure your valve stems are not gummy from old fuel varnish. soak your valve guides with penetrating products till you know they are free. Otherwise can cause serious hard to fix damage.
Thank you very much. I did find the following Spring Wake Up thread in the Tech Tip, which will help the owner a lot.
https://www.stovebolt.com/techtips/spring_wake_up.html
Yes for soaking the valve guides before first turnover.
Craig
H Online: Content
KROIL is your friend when waking up an engine after a long sleep.
www.kanolabs.com
cmayna, Joe Apple provided the link to the Tech Tip. Good luck
joe apple, thanks for the link. I made a copy to give to the owner. Also told him to join Stovebolt.
Craig
Moderated
Moderated
either in a gas engine?wow
While either is not recommended for gas engines it can be a useful tool if applied sparingly. Been done millions of times with no ill effects. Just don’t be heavy handed with your finger on the nozzle.
24601
24601
If you go through the simple, yet methodical steps in the "Bringing a dead engine back to life" Tech Tip, there should be no need for ether. Just follow the Tech Tip -- Look at who helped me put it together -- easily several centuries of experience represented there.
Friday afternoon, we brought a sleeping diesel back to life after at least a decade of dormancy. Of course the steps are a little different for a diesel, its basically the same methodical approach to avoid causing serious damage.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John, the “Spring wake up” Tech Tip instructs the user to spray either. Just FYI
I hope the owner of the dormant '54 gets to the point of having to decide ether or not. A lot of work is needed before that point.
Craig
Ether is an either or proposition…
6 heaven
6 heaven
I also like to overfill the crankcase with extra oil, maybe even automatic transmission fluid before turning the engine over. If it is overfilled enough, the rear main seal(rope style) may be able to get some lubrication instead of being dry when the engine is turned over. I don't think the extra oil will hurt anything when first started, but for sure the rear seal is gonna be dry on startup.
We have a couple of Accusump pre-lubers which are a bit pricey but easy to make. If regulated air is used the container can even be PVC. A can with a couple quarts of oil has a line to the oil galley plug and air pressure (30 lbs) is applied to the top of the oil in can. The engine is turned to 0-90-180-270 position to be sure oil is distributed everywhere. Should show on oil pressure gauge. If pan plug is pulled you can push as much pre-lube oil through as you care to. The engine will think it has been run minutes before.
Evan
