1 members (Peggy M),
129
Mod | | | Forums66 Topics128,186 Posts1,057,307 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Tomorrow I am going to meet someone who has a '54 3100 series which has been sitting since 2003. He wants to restore it but first wants to get it back up and running. What is the best priority list for him to follow. Yes, change all fluids, check brakes, etc. I'm concerned about having new oil at the valve train when he cranks the motor over for the first time. Yes for turning the motor over by hand just to make sure nothing is bound up. So, if someone has a basic TODO list of what to look at, change, etc, that would be very helpful.
Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Craig, check the Tech Tips. There is a very good one there for the taking!
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | #1 on my list is to avoid using any gas whatsoever via the gas tank. Use a small boat tank. Leave the priming bulb on it to prime the fuel pump.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Oil all the valves, then tap each one with a rubber hammer or 2 x 4 to make sure they are not stuck, BEFORE turning the engine over by hand.
Ed
| | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | Wouldn't hurt to also pour a little ATF in all the cylinders and let it sit a while before turning the engine over. Leave the plugs out when you first turn it over to blow the ATF back out. | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Martin, Which particular Tech Tip were you referring to? There are so many tips but haven't found one yet which is a semi simple list for one to use that covers many of the "todo"'s.
52Carl, Ed & Rich - Thanks for the very valuable suggestions. Will pass them along.
Will be going to see the rig today.
| | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | cmayna The main thing is to be sure your valve stems are not gummy from old fuel varnish. soak your valve guides with penetrating products till you know they are free. Otherwise can cause serious hard to fix damage. | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Thank you very much. I did find the following Spring Wake Up thread in the Tech Tip, which will help the owner a lot. https://www.stovebolt.com/techtips/spring_wake_up.htmlYes for soaking the valve guides before first turnover.
| | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | KROIL is your friend when waking up an engine after a long sleep. www.kanolabs.comJerry
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | cmayna, Joe Apple provided the link to the Tech Tip. Good luck
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | joe apple, thanks for the link. I made a copy to give to the owner. Also told him to join Stovebolt.
| | | | | Joined: Mar 2021 Posts: 1 Moderated | | Moderated Joined: Mar 2021 Posts: 1 | either in a gas engine?wow | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | While either is not recommended for gas engines it can be a useful tool if applied sparingly. Been done millions of times with no ill effects. Just don’t be heavy handed with your finger on the nozzle.
| | | | | Joined: Nov 1995 Posts: 5,746 24601 | | 24601 Joined: Nov 1995 Posts: 5,746 | If you go through the simple, yet methodical steps in the "Bringing a dead engine back to life" Tech Tip, there should be no need for ether. Just follow the Tech Tip -- Look at who helped me put it together -- easily several centuries of experience represented there.
Friday afternoon, we brought a sleeping diesel back to life after at least a decade of dormancy. Of course the steps are a little different for a diesel, its basically the same methodical approach to avoid causing serious damage.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | John, the “Spring wake up” Tech Tip instructs the user to spray either. Just FYI
| | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | I hope the owner of the dormant '54 gets to the point of having to decide ether or not. A lot of work is needed before that point.
| | | | | Joined: Nov 2020 Posts: 789 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 789 | Ether is an either or proposition… | | | | | Joined: Aug 2005 Posts: 125 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 125 | I also like to overfill the crankcase with extra oil, maybe even automatic transmission fluid before turning the engine over. If it is overfilled enough, the rear main seal(rope style) may be able to get some lubrication instead of being dry when the engine is turned over. I don't think the extra oil will hurt anything when first started, but for sure the rear seal is gonna be dry on startup. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have a couple of Accusump pre-lubers which are a bit pricey but easy to make. If regulated air is used the container can even be PVC. A can with a couple quarts of oil has a line to the oil galley plug and air pressure (30 lbs) is applied to the top of the oil in can. The engine is turned to 0-90-180-270 position to be sure oil is distributed everywhere. Should show on oil pressure gauge. If pan plug is pulled you can push as much pre-lube oil through as you care to. The engine will think it has been run minutes before.
Evan
