6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
Apprentice
Apprentice
I have searched our site here for this info, and while this issue is addressed for other trucks I do not see anything for this particular usage. What is the torque spec for the front wheel bearing (ball bearing) retaining nut on a '54 1.5 ton? Also, any tips/tricks/proceedure I need to know about that?
I took it apart to replace the wheel cylinder and am now putting it back together. I did not remove the inner bearing. I cleaned it in place and re-greased it -- hopefully sufficiently.
Thanks in advance!
Bolter Rush, Cave Springs, AR
1954 Chevrolet 4400 Flat Bed Dump, 1972 Chevrolet long bed.
Email: mikeshahan1960@gmail.com
I just snug it up...to zero clearance, and then back it off an 1/8 to a 1/4 turn where the cotter key will line up...you can tighten it till ya just feel a slight drag on the wheel then back it off a little....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Apprentice
Apprentice
That sounds like how I did them years ago on my camaro's, etc., but I wanted to be sure. I thought I read some threads about other trucks going from between 20 and 30 foot/pounds so I thought I better ask.
I know that when I took it apart it seemed to be about finger tight or so.
Thanks for the quick reply!
I tighten the nut until the end play is gone, then loosen, then tighten. Do this a few times to seat the bearing into the grease. The final time I tighten it to no end play I then tighten to the next available cotter pin notch. I prefer a little preload as apposed to a loose wheel bearing.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
Thanks Scott. Is there any danger of burning up the bearing by doing it this way? Can I over-tighten or over-load the bearing if I'm not careful?
X
X Offline
The shop manual says to tighten to 33 lb-ft while turning the hub, then back off the nut to align to the nearest hole in the spindle for the cotter pin.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Apprentice
Apprentice
Excellent! Thanks very much. That puts my mind at ease.
Can you tell me where I can get a shop manual for this truck?
Thanks again.
Bolter Rush,
As per Peg, click on the American Classic icon at the top of the page...put your year truck in and look under "L" for literature. I have the same style truck as you, although mine isn't a dumper!
Stuart
Apprentice
Apprentice
Thanks very much everyone. I've been a member here for awhile but I'm still amazed at how great this site is.
Thanks everyone. You've been a huge help.
